badler4
Jan 29, 2021Aspirant
RBR50 slow wired speeds
I check the speed test on the Orbi app, and I'm getting 600-750Mbps (paying for 912Mbps from Spectrum). I have a wired connection, Cat 8, from my ethernet port on the Orbi router to my laptop dockin...
vajim
Jan 29, 2021Master
can you try it without the docking station?
- badler4Jan 29, 2021Aspirant
directly connected now from orbi ethernet port to laptop.
- FURRYe38Jan 29, 2021Guru - Experienced User
Is Armor, Circle or Traffic Meter enabed on the RBR?
- badler4Jan 29, 2021AspirantYes, the traffic meter is enabled. I have had to step away from home for the moment, but I can try and disable it later if you think this might be something that is rattling down the speed.
