badler4
Jan 29, 2021Aspirant
RBR50 slow wired speeds
I check the speed test on the Orbi app, and I'm getting 600-750Mbps (paying for 912Mbps from Spectrum). I have a wired connection, Cat 8, from my ethernet port on the Orbi router to my laptop dockin...
vajim
Jan 29, 2021Master
can you try it without the docking station?
badler4
directly connected now from orbi ethernet port to laptop.
- FURRYe38Jan 29, 2021Guru - Experienced User
Is Armor, Circle or Traffic Meter enabed on the RBR?
- badler4Jan 29, 2021AspirantYes, the traffic meter is enabled. I have had to step away from home for the moment, but I can try and disable it later if you think this might be something that is rattling down the speed.
There was posts a while back that mentioned Traffic meter causing speeds not to be where they are at. Try disabling it, if no change, I would factory reset and setup from scratch and be sure not to enable the aforementioned features. Wired speed should be to spec then.
