jefferis
Oct 29, 2024Guide
RBR50 slows to a crawl till I reboot
Firmware is current V2.7.4.24 In the last few days, I thought my internet provider was slowing down, but I have narrowed it to the RBR50 The problem clears after a reboot. What happens is ...
- Oct 30, 2024
WOW, well thank you to all. I finally got it working but it was so weird how I did it.
I first had to go to manual update, then select a satellite (even though it said no updates were available) and then go back to Online update and login and upload the file and then run the firmware update. I had to do that for each satellite in turn and then the router .
Doesn't make sense but finally everything is up to date.
Oct 30, 2024Guru - Experienced User
Are the extracted FW files .IMG or .CHK?
Can you try using a Windows PC?
What Apple OSX version are you using on Mac?
jefferis
Oct 30, 2024Guide
