Johnhorton1979
Oct 31, 2022Aspirant
RBR50 Solid Purple/Magenta light after power cut
Hi all I have an issue with my RBR50 after a powercut i now cannot get it working there is a solid purple light, I have run through all the trouble shooting for resetiing but the reset doesnt seem t...
Oct 31, 2022Guru - Experienced User
So if you disconnect the RBR from the modem and press the reset button for 15 seconds then release and with 1 wired PC connected to the RBR, after the top ring LED slowly pulsates WHITE, can you access the RBRs web page at 192.168.1.1 at all?
- Johnhorton1979Oct 31, 2022Aspirant
the current firmware version is RBR50-V2.7.4.24
Im not able to access the router admin at 192.168.1.1 when the LED is slowly blinking white
I have done the reset as you mentioned too however it does not seem to be able to reset as still shows the exisiting network details
My model is a Netgear Superhub 4 from virgin media in modem mode and confimed this as working as it should
- FURRYe38Oct 31, 2022Guru - Experienced User
Does swapping the power adapter from the RBS50 change anything?
Might try the recovery method and re-load the v.24 FW file on to the RBR:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflashIf all this fails, I would presume the RBR is faulty and needs replacing.
Thanks for the prompt repsonse
I have tried the tfpt method and just keeps timing out using MacOS im about to try with a windows 11 machine to see if it works.
The strange thing is it does seems to work as an Access point, but i cant get into anything admin wise for it
