Johnhorton1979
Oct 31, 2022Aspirant
RBR50 Solid Purple/Magenta light after power cut
Hi all I have an issue with my RBR50 after a powercut i now cannot get it working there is a solid purple light, I have run through all the trouble shooting for resetiing but the reset doesnt seem t...
Oct 31, 2022Guru - Experienced User
So if you disconnect the RBR from the modem and press the reset button for 15 seconds then release and with 1 wired PC connected to the RBR, after the top ring LED slowly pulsates WHITE, can you access the RBRs web page at 192.168.1.1 at all?
Johnhorton1979
the current firmware version is RBR50-V2.7.4.24
Im not able to access the router admin at 192.168.1.1 when the LED is slowly blinking white
I have done the reset as you mentioned too however it does not seem to be able to reset as still shows the exisiting network details
My model is a Netgear Superhub 4 from virgin media in modem mode and confimed this as working as it should
- FURRYe38Oct 31, 2022Guru - Experienced User
Does swapping the power adapter from the RBS50 change anything?
Might try the recovery method and re-load the v.24 FW file on to the RBR:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
Make sure you enable tftp: https://www.thewindowsclub.com/enable-tftp-windows-10
Video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done:
https://www.youtube.com/watch?v=R9DLrLQrpaw
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a Windows 7 PC and the TFTP worked.
Mac TFTP: https://www.petenetlive.com/KB/Article/0001247
Try nmrpflash:
https://github.com/jclehner/nmrpflashIf all this fails, I would presume the RBR is faulty and needs replacing.
- Johnhorton1979Oct 31, 2022Aspirant
Thanks for the prompt repsonse
I have tried the tfpt method and just keeps timing out using MacOS im about to try with a windows 11 machine to see if it works.
The strange thing is it does seems to work as an Access point, but i cant get into anything admin wise for it
- FURRYe38Nov 02, 2022Guru - Experienced User
Were you able to try a Windows PC?
