TiaMaster
Aug 14, 2018Aspirant
RBR50 Solid White RIng
I have the Orbi connected as a secondary router, providing my wireless network. Ever since our power went out during a storm, it has never come online and has a solid white ring on top.
I have res...
TiaMaster
Aug 15, 2018Aspirant
Panoramic TG1682.
The top LED does everything its normally does, so yes. But then it turns solid white. During none of this is the router reachable.
Aug 15, 2018Guru - Experienced User
I would contact NG support about this. Maybe a problem with the router that we can't help with here.
Also be ware if your ISP modem:
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, LAN to LAN and configure AP mode on the Orbi router.
