Krushmoto
May 06, 2021Aspirant
RBR50 Speed now 7mbps
Purchased my RBR50 2 years ago and it ran great until 2 weeks ago. I have gigbit speeds w/ RCN. I'm averaging 7mbps on speedtest.net. I was on firmware 2.7 but downgraded back to 2.6 after readin...
May 06, 2021Guru - Experienced User
Are you speed testing with a wired PC or wireless device?
Do all devices show this same speed result?
Do you get same results directly connected to the ISP modem?
Krushmoto
May 07, 2021Aspirant
Using a NG CM1000 cable modem. Not using the satellites at this time. Unable to speed test using wire, laptop doesn't have a Ethernet port but I do have another router which is giving normal speeds. The Asus router is providing 422/24.8 Mbps while the Orbi is providing 7.27/7.25 Mbps. The other thing I noticed was while the Asus selects a local server the Orbi is selecting a server in NYC. I'm in NE PA. Orbi used to select a local server.
