Krushmoto
May 06, 2021Aspirant
RBR50 Speed now 7mbps
Purchased my RBR50 2 years ago and it ran great until 2 weeks ago. I have gigbit speeds w/ RCN. I'm averaging 7mbps on speedtest.net. I was on firmware 2.7 but downgraded back to 2.6 after readin...
Krushmoto
May 07, 2021Aspirant
Not using the satellites at this time, just the router.
- FURRYe38May 07, 2021Guru - Experienced User
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settingsMight setup the RBR using some of these suggestions:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026I would not enabled Armor, Access Controls, Circle or Traffic Meter. Just run some speed tests with Ooklas installable speed test app first.
There are inexpensive USB to ethernet adapters for laptops with out ethernet ports.
- KrushmotoMay 19, 2021Aspirant
Sorry for the late reply. Got the usb adapter and tried resetting and hardwiring to the router but still no change. Hardwire and wifi both are 7mbps so I have to think something is wrong with my 2 year old Orbi. Using the new Asus router I get 225mpbs on wifi.
Any suggestions or is the Orbi dead?
- FURRYe38May 21, 2021Guru - Experienced User
If you set the ASUS router as your main router, disable all wifi radios on the router. Then configure the RBR for AP mode, wire connect it to the ASUS router and wire one PC to the RBR first and speed test with the PC, results the same or any better?
Krushmoto wrote:Sorry for the late reply. Got the usb adapter and tried resetting and hardwiring to the router but still no change. Hardwire and wifi both are 7mbps so I have to think something is wrong with my 2 year old Orbi. Using the new Asus router I get 225mpbs on wifi.
