Krushmoto
May 06, 2021Aspirant
RBR50 Speed now 7mbps
Purchased my RBR50 2 years ago and it ran great until 2 weeks ago. I have gigbit speeds w/ RCN. I'm averaging 7mbps on speedtest.net. I was on firmware 2.7 but downgraded back to 2.6 after readin...
May 07, 2021Guru - Experienced User
I would power OFF the ISP modem for 1 minute. Factory reset the Orbi router and power it off. Power ON the ISP modem and let it sync. Then power ON the Orbi router and walk thru the setup wizard again using a wired PC and a web browser.
Press the back reset button for 15 seconds then release.
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Might setup the RBR using some of these suggestions:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
I would not enabled Armor, Access Controls, Circle or Traffic Meter. Just run some speed tests with Ooklas installable speed test app first.
There are inexpensive USB to ethernet adapters for laptops with out ethernet ports.
Krushmoto
May 19, 2021Aspirant
Sorry for the late reply. Got the usb adapter and tried resetting and hardwiring to the router but still no change. Hardwire and wifi both are 7mbps so I have to think something is wrong with my 2 year old Orbi. Using the new Asus router I get 225mpbs on wifi.
Any suggestions or is the Orbi dead?
