PCOPPOLA5373
Apr 11, 2018Follower
RBR50 Speed Test Failing
Can no longer use the ORBI app on my iPhone to condust a speed test. This problem just started within a week. When I try I get: Connection Failed If the problem persists, try rebooting your router...
daddybo3
Apr 12, 2018Aspirant
I am experiencing the same problems with the app speed test. It was working perfectly until I updated to firmware v 2.1.3.4. I have rebooted the router as suggested. I have deleted an reinstalled the app. Nothing seems to work...
Apr 12, 2018Guru - Experienced User
Have you reverted back to FW that was working?
daddybo3 wrote:I am experiencing the same problems with the app speed test. It was working perfectly until I updated to firmware v 2.1.3.4. I have rebooted the router as suggested. I have deleted an reinstalled the app. Nothing seems to work...
- OrbiDemigodApr 12, 2018Apprentice
This router is such garbage it makes me mad.
- CatherineA949Apr 17, 2018GuideTry the speed test again, several others worked today!
