cortex
Jan 11, 2021Aspirant
RBR50 spontaneously bricked itself this morning - factory reset has no effect - what are my options?
I woke up to find I had no wifi and no internet. My two satellites had solid magenta rings. The router had power but no illuminated ring. I I tried to connect directly to the router via ethernet I co...
Jan 11, 2021Guru - Experienced User
Try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
If tftp doesn't work, try nmrpflash.
I've had luck with that when tftp didn't work.
- cortexJan 12, 2021Aspirant
plemans wrote:If tftp doesn't work, try nmrpflash.
https://github.com/jclehner/nmrpflash
Thanks for the suggestion. I tried it and it didn't work/was not able to flash the firmware. It never detects the router once turned on ("Waiting for physical connection." leads to "Error: Ethernet cable is unplugged."). I tried all the ports.
- FURRYe38Jan 12, 2021Guru - Experienced User
Sounds like your RBR is bad. I would make contact with NG support to see what your options are.
- CrimpOnJan 14, 2021Guru - Experienced User
Thanks for the link. Noticed that no Orbi models are included in the ReadMe information.
You have had luck using nmrpflash on an Orbi?
