cortex
Jan 11, 2021Aspirant
RBR50 spontaneously bricked itself this morning - factory reset has no effect - what are my options?
I woke up to find I had no wifi and no internet. My two satellites had solid magenta rings. The router had power but no illuminated ring. I I tried to connect directly to the router via ethernet I co...
Jan 11, 2021Guru - Experienced User
If tftp doesn't work, try nmrpflash.
I've had luck with that when tftp didn't work.
cortex
Jan 12, 2021Aspirant
plemans wrote:If tftp doesn't work, try nmrpflash.
https://github.com/jclehner/nmrpflash
Thanks for the suggestion. I tried it and it didn't work/was not able to flash the firmware. It never detects the router once turned on ("Waiting for physical connection." leads to "Error: Ethernet cable is unplugged."). I tried all the ports.
- FURRYe38Jan 12, 2021Guru - Experienced User
Sounds like your RBR is bad. I would make contact with NG support to see what your options are.
