TaoKao
Feb 14, 2021Aspirant
RBR50 SSID=NETGEAR41, after reset see ORBI57 but neither default or my password unlock router
I was having some router issues after a circuit got tripped (the RBR50 is on a UPS whidh did not stay up before I reset the circuit). Could not get the RBR50 to come cleanly up and stable. Decided ...
- Feb 14, 2021
There may be a misconception over how fast things happen when resetting an Orbi. I just did a Factory Reset on my spare Orbi:
Time 0 seconds - press paperclip into reset hold. Power LED turns Orange immediately, then begins to flash
10 seconds - remove paperclip from reset hole. Power LED turns Green
Ring light on top begins to cycle on/off. Not "fade", simply on/off.
1:05 Ring light begins to fade on/ fade off
2:40 Ring light turns solid white. (and seems to stay on solid white until I "do something".
Connect ethernet cable (or log into the WiFi using the SSID/password on the product label. I prefer the ethernet cable.)
NOTE: I leave my network adapter on "get an IP address using DHCP. I do not set a static IP on my computer.
The Orbi's IP will be my "gateway" address. (Most of the time, this is 192.168.1.1. In MY case, this Orbi is connected to another Orbi that has already taken 192.168.1.1, so this Orbi decided to use 10.0.0.1)
Open a web browser and connect to http://orbilogin.net (or, the gateway IP)
IThe screen comes up "For fastest setup...". I ignore that, scroll down to the bottom and click on "If you don't have a compatible smartphone..."
Answer a bunch of questions. Skip satellite setup (do that later) Enter new admin password & security questions. Set up WiFi SSID/password.. ignore registration (done that already). ignore offers..... yada yada yada.
White light remains ON.
There should be NO HURRY.
TaoKao
CrimpOn wrote:As to the NETGEAR41 SSID, that sounds like there is a "non-Orbi" WiFi system nearby.
I can definitely tie the NETGEAR41 to powering on and off the RBR50. My Satellite is powered down.
CrimpOn
Feb 14, 2021Guru - Experienced User
- TaoKaoFeb 15, 2021Aspirant
I am still having problems getting through the process without link dropping and thereby stalling the process. Going to keep trying but am also going to assume that there is a hardware problem that is root cause. Time to shop the Wifi v6 routers... Too bad I cannot salvage the Satelliite RBS70 that would save some money.
