feinberj
Jun 07, 2023Tutor
RBR50 started assigning 192.168.10.x instead of 192.168.0.x to Apple devices
I have been using a Netgear Orbi RBR50 for many years, and it's worked well. I've configured my internal network (wired and wifi) to assign addresses of 192.168.0.x (third digit zero), with many add...
Jun 07, 2023Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
- feinberjJun 07, 2023Tutor
I forgot to post the firmware version! It is V2.7.4.24, same for the RBR50 and the two RBS50 satellites. It's connected directly to a Verizon FIOS Alcatel ONT I-211M-L. The NetGear Orbi handles DHCP assignments - it plugs directly into the ONT. I.e. I'm not using any Verizon routers, only the ONT.
I can try your reset sequence later tonight. I'll get in a lot of trouble if I take the network down during the day! 🙂
John
- FURRYe38Jun 07, 2023Guru - Experienced User
Might update FW as well when you get time:
I had gone to the Advanced -> Administration -> Firmware Update section of the admin module. It says that there is no new firmware version available. I didn't realize there was a newer firmware version available for manual installation! I'll definitely consider giving it a try.
