feinberj
Jun 07, 2023Tutor
RBR50 started assigning 192.168.10.x instead of 192.168.0.x to Apple devices
I have been using a Netgear Orbi RBR50 for many years, and it's worked well. I've configured my internal network (wired and wifi) to assign addresses of 192.168.0.x (third digit zero), with many add...
Jun 07, 2023Guru - Experienced User
Might update FW as well when you get time:
feinberj
Jun 07, 2023Tutor
I had gone to the Advanced -> Administration -> Firmware Update section of the admin module. It says that there is no new firmware version available. I didn't realize there was a newer firmware version available for manual installation! I'll definitely consider giving it a try.
- FURRYe38Jun 07, 2023Guru - Experienced User
Sometimes new FW doesn't get put up on the AU servers. Minor updates mostly. Major ones seem to get put up when those happen.
- CrimpOnJun 07, 2023Guru - Experienced User
Do these DHCP assignments to Apple devices show up in the Orbi Log File?
Did anything happen "about a week ago?"
- Was there an iOS software update?
- Any new devices connected?
This sound suspiciously like there is another DHCP server on the network.
