ktpmm5
Apr 27, 2025Aspirant
RBR50 steady white light and can't connect to orbilogin.net
I've got an Orbi RBR50 and RBS50, with a Verizon G1100 modem. Everything worked perfectly until this morning when the Verizon tech rebooted my router to troubleshoot. My modem reboot worked but the...
- Apr 29, 2025
When connected to the Orbi system with a PC, what IP address do you find on your PC? Should be a 10.x IP address string.
Try 10.0.0.1 in a web browser with a PC connected to the RBR?
Might contact your ISP to have them help you ensure the ISP router is configured correctly for items 1 or 2 listed in the suggestions for ISP modems that have built in routers.
Or give item #3 a try on the RBR.
Apr 28, 2025Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and router and satellites been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router.
https://community.netgear.com/t5/Orbi-WIFI-6-AX-AND-Wi-Fi-6E-AXE/Procedure-for-Factory-reset-of-RBS850/m-p/2367505/highlight/true#M53985
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
- ktpmm5Apr 28, 2025Aspirant
Thanks for that info. I tried all of that with no luck.
I did restore my modem settings from a few days ago, when everything worked. Wireless is off on my modem. From the modem's LAN port I have Ethernet to the Orbi's Internet port.
I cannot get to orbilogin.net or .com. When I try to connect to the orbiXX network, it will not connect. Same thing with the Orbi app.
When I look at my modem's network settings, I now see the RBR50 is connected to my FIOS modem with an ip of 192.1681.X. The status however is listed as blocked.
I'm pretty confused at this point about why the modem appears to be blocking access to the Orbi. I have no parental controls, access controls, etc.- FURRYe38Apr 29, 2025Guru - Experienced User
- ktpmm5Apr 29, 2025Aspirant
When I connect from my laptop I get a 172.27.1.X address. But I cannot access this IP via browser.
