ktpmm5's avatar
ktpmm5
RBR50 steady white light and can't connect to orbilogin.net
I've got an Orbi RBR50 and RBS50, with a Verizon G1100 modem.  Everything worked perfectly until this morning when the Verizon tech rebooted my router to troubleshoot.  My modem reboot worked but the...
  • FURRYe38's avatar
    When connected to the Orbi system with a PC, what IP address do you find on your PC? Should be a 10.x IP address string.
    Try 10.0.0.1 in a web browser with a PC connected to the RBR?
    Might contact your ISP to have them help you ensure the ISP router is configured correctly for items 1 or 2 listed in the suggestions for ISP modems that have built in routers.
    Or give item #3 a try on the RBR.
