wmartret
Dec 21, 2021Tutor
RBR50 stops working
Model:RBR50 Firmware v2.7.3.22 Hello Since some days, the RBR50 stops responding, and seems to be powered off as the power led is off, even if the power button is on. Did someone encount...
wmartret
Dec 22, 2021Tutor
Hi,
thanks for your answer. I swapped the 2 power supplies, but the issue stays on the router.
I changed wifi channels for 2,4 and 5ghz, but seems now the don't stop restarting.
Do you know if debug mode is available to get more logs about the rbr50?
Dec 22, 2021Guru - Experienced User
if the power light wasn't even on, how were you able to access it?
did you try a factory reset? Push and hold reset for 7-15 seconds while powered on?
- wmartretDec 22, 2021Tutor
Hi,
I saw before being down a software initialization phase in the journalization log.
before testing factory reset, I switch from router mode to AP mode. I now wait for result.
- wmartretDec 24, 2021Tutor
Hi
AP mode was unsuccessfull, so I made a factory reset. yesterday evening. And I get the same issue this morning, router was off. I had to switch off/on the power button. Think this is a hardware issue.
the pack is still under warranty period. I will go back to the merchant with my problem
thank for your answers
- plemansDec 24, 2021Guru - Experienced User
If its under warranty, probably the best choice
