wmartret
Dec 21, 2021Tutor
RBR50 stops working
Model:RBR50 Firmware v2.7.3.22 Hello Since some days, the RBR50 stops responding, and seems to be powered off as the power led is off, even if the power button is on. Did someone encount...
Mikey94025
Dec 24, 2021Hero
wmartret wrote:Model:RBR50
Firmware v2.7.3.22
Hello
Note that the main light on the Orbi does not stay on all the time: https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-router-and-satellite-mean.
- OFF. Your Orbi router and satellite are working normally.
Therefore if you don't see the light, it doesn't mean it's powered off. The "stops responding" is a problem that needs investigating, but it may not be just a power issue. Regardless, if it is under warranty you should best contact Netgear Support and let them help you.
