chenhli
May 08, 2019Tutor
RBR50 Suddenly Stopped Working
Hello,
On 1/8/2019, I purchased the RBK50 Wifi system from BestBuy in Michigan, USA.
I gave the system to my parents, and they took it back to Taiwan (where they live now) to enhance thei...
- May 09, 2019Solution found. No further response needed.
newak47
May 29, 2019Aspirant
V1.8.0.6
And it's saying "No new firmware version available" when I log in to Orbilogin.net so can't seem to update that way.
Was hoping it would update itself, as I'm loathe to touch it - but nothing so far. Will look into updating manually, but not sure how to connect directly to PC. Any tips?!
May 29, 2019Guru - Experienced User
Yes, download v2.0.0.74 FW files for both RBR and RBS. Apply the FW file to the RBS first, then the RBR lastly. After that, you can apply the latest v60 FW file to the RBS first.
The RBR it was required to apply v212 first then you can apply v32 or later version up to v60. Not sure if you can go directly from v2.0.0.74 to v60 on the RBR with out the v212. I would apply the v212 first on the RBR then apply v60.
newak47 wrote:V1.8.0.6
