jameswang510
Nov 18, 2019Aspirant
RBR50 system failure
I have a RBK53 system which has been working perfectly for almost 1 year. However, 2 dyas ago, the router (RBR50) had some connection problems could not be solved by rebooting the system. So I press ...
jameswang510
Thank you for your reply, the main problem now is I can not even set up the system by its APP not to mention rename the SSID name. During the factory reset, I saw the power LED light turn amber, and then begin to flash amber at the begining, however it became solid green at last. There was a time the LED turned amber, and then begining to flash amber a few times and it finally falshed red.
CrimpOn
Nov 18, 2019Guru - Experienced User
Once it begins to flash amber, stop holding the paperclip in and begin the setup. Red is definitely bad.
- jameswang510Nov 18, 2019Aspirant
I tried again few minutes ago, this time the LED was solid green no matter how long I held the paperclip, I think the router is done:smileysad:
