jameswang510
Nov 18, 2019Aspirant
RBR50 system failure
I have a RBK53 system which has been working perfectly for almost 1 year. However, 2 dyas ago, the router (RBR50) had some connection problems could not be solved by rebooting the system. So I press ...
Nov 19, 2019Guru - Experienced User
Can you access the RBRs web page after a reset? If so,Try this, download the FW file for the RBR on to a wired PC. I connect the wired PC to the RBR. If you can access the RBRs web page, resend the FW file for the RBR. After it completes, and reboots. Press the reset button for 15 seconds only on the RBR and then let go. Can you walk thru the setup wizard and complete it and set a new SSID and PW?
jameswang510 wrote:I have a RBK53 system which has been working perfectly for almost 1 year. However, 2 dyas ago, the router (RBR50) had some connection problems could not be solved by rebooting the system. So I press the reset button, but after that I failed to connect with the RBR50 because both SSID and IP address could not be found by either cellphone wifi or cable connection with a PC. The led light of RBR50 starts to blink in white and the power light stays in green. Now I put a cable in the LAN port of RBR50 and anthoer cable is used to link the RBS50 and RBR50 together. Surprisingly, it still has internet connection on the cable and the default SSID of the RBS50 can be connected by portable devices. When I power off the RBS50 the SSID will disappear. What seems to be the problem ? How am I suppose to repair the connection with RBR50 ?
- jameswang510Nov 19, 2019Aspirant
I can not access the RBRs web page after a reset, because no IP address is sent to downstream devices by this RBR. The interesting thing is 2 RBSs are still working, I can access them by their own IP and WIFI SSID, however their WIFI have no internet connection but my PC can access to internet by wired to one of the RBS.
- FURRYe38Nov 19, 2019Guru - Experienced User
Ok, was wondering is all. Sounds like the RBR needs to be replaced then. :smileysad:
Indeed, but the NETGEAR refuse to give me a new one, they said if you cannot offer the purchase proof no warranty will be granted.:smileyfrustrated:
