liquid1287
Mar 04, 2021Tutor
RBR50 that was working fine. Now I can't factory reset it. with xfi CGM4331COM
I have an Orbi RBR50 router that was hooked up to my own arris modem. Satelite was hooked up via wired backhaul. Everything working fine. I was forced to upgrade to xfi for unlimited data. Xfi setup ...
vajim
Mar 04, 2021Master
wow, what a mess
I can only offer the following:
forget the app, too many problems being reported
i woud keep trying the factory reset
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
sounds like you already knmow about this:
https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point
final recommendation: if possible get a 'regular' non-wifi modem and run the orbi straight up.
- liquid1287Mar 10, 2021Tutor
Well I reset it about 4 more times and it worked! No rhyme or reason but i got it working with the comcast modem in bridge mode. I also had to avoid the app and hard connect to the Orbi. BUT it's working!
- vajimMar 10, 2021Master
liquid1287 wrote:Well I reset it about 4 more times and it worked! No rhyme or reason but i got it working with the comcast modem in bridge mode. I also had to avoid the app and hard connect to the Orbi. BUT it's working!
nice work...now go enjoy:smileyhappy: your favorite bevage as your Orbi does what it's suppose to do
