NorthernApe
Aug 31, 2021Aspirant
RBR50 to RBS50 connectivity issue
I have an RBR50 connected directly to a BT Openreach ONT and running in router mode. The internet connection is up and running and stable. There are two RBS50 satellites spread through the ground flo...
- Sep 01, 2021
I think I have accepted that getting the satellites hard-wired using powerline adaptors is pretty much dead in the water and there doesn't seem to be that great an advantage speed-wise over the MESH network anyway!
With that in mind, can I get an opinion on the optimum settings for the Orbi router? Attached is a screenshot of the wireless settings.
Aug 31, 2021Guru - Experienced User
a couple things.
1. running 2 routers in router mode can cause issues. its called a double nat. https://kb.netgear.com/30186/What-is-Double-NAT
2. Is there a powerline adapter connected back to the bt openreach router or just to the orbi router?
3. powerline is sensitive to interference and a lot of things can interfere with powerline. these include: electronics going bad, cheap cell phone chargers, high draw appliances, old/bad/cheap/sketchy wiring, arc fault circuits, gfci outlets, surge protectors, and poorly made electronics. If the powerline backhaul isn't staying stable/connected, I'd be looking at the powerline system and not the orbi system.
