NorthernApe's avatar
NorthernApe
RBR50 to RBS50 connectivity issue
I have an RBR50 connected directly to a BT Openreach ONT and running in router mode. The internet connection is up and running and stable. There are two RBS50 satellites spread through the ground flo...
  • NorthernApe's avatar
    NorthernApe
    Sep 01, 2021
    I think I have accepted that getting the satellites hard-wired using powerline adaptors is pretty much dead in the water and there doesn't seem to be that great an advantage speed-wise over the MESH network anyway!
    With that in mind, can I get an opinion on the optimum settings for the Orbi router? Attached is a screenshot of the wireless settings.
