Liquidcore
Nov 16, 2019Star
RBR50 unable to handle gigabit connection?
Hi there, I recently purchased the RBK50 to improve the WiFi range in my house and have configured the RBR50 as a router rather than an AP but it seems to be having trouble handling my gigabit connect...
Nov 17, 2019Guru - Experienced User
The version of FW isn't the problem as this has been on going since before v38:
Liquidcore wrote:
Hi there, I recently purchased the RBK50 to improve the WiFi range in my house and have configured the RBR50 as a router rather than an AP but it seems to be having trouble handling my gigabit connection. Firmware is 2.5.0.38.
My connection is 900/500, PPPoE, vlan 10 tagging. The ONT is a Nokia G-140W-C.
Using the internal Speedtest app in both scenarios:
ONT -> RBR50 - speeds around 400 down/300 up
ONT -> Fritzbox -> RBR50 (AP mode) - speeds around 900 down/500 up
This suggests to me that the RBR50 cannot handle the routing of a gigabit connection.
Has anybody had similar experiences?
Thanks!
- AnonymousNov 17, 2019
FURRYe38 wrote:The version of FW isn't the problem as this has been on going since before v38:
Yes it is. Admit the truth
was the the network ever working?
why not change the firmware?
Thanks!
