Liquidcore
Nov 16, 2019Star
RBR50 unable to handle gigabit connection?
Hi there, I recently purchased the RBK50 to improve the WiFi range in my house and have configured the RBR50 as a router rather than an AP but it seems to be having trouble handling my gigabit connect...
Nov 18, 2019Guru - Experienced User
Liquidcore and Mitch2k2 and anyone else not seeing near 900Mbps with there Orbi routers with wired speed tests. I was contacted by NG support today. There looking into this. Asked for some debug logs and configuration of my test software.
For those if you who are having problems, can you please log into the following web page on the RBR and enable WAN/LAN Packet capture then start the debug capture.
http:\\192.168.1.1\debug.htm
When you start the debug log capture, access routers UI and run speedtest (Advanced TAB > Setup > Speed Test). Once done, you can save the logs.
I would also re-start the WAN/LAN packet capture again and start debug logs then run a speed test with Ooklas installable speed test app for a wire connected Windows or Mac PC. Once done, you can save the logs.
Mitch2k2
Nov 18, 2019Aspirant
To whom/where should we send these logs?
