Liquidcore
Nov 16, 2019Star
RBR50 unable to handle gigabit connection?
Hi there, I recently purchased the RBK50 to improve the WiFi range in my house and have configured the RBR50 as a router rather than an AP but it seems to be having trouble handling my gigabit connect...
Mitch2k2
Nov 18, 2019Aspirant
I've been experiencing basically the same exact situation.
Edited to add: ...but I'm using the 2.3.5.30 fw
Liquidcore wrote:
This suggests to me that the RBR50 cannot handle the routing of a gigabit connection.
Has anybody had similar experiences?
Blanca_O
Nov 19, 2019NETGEAR Employee Retired
Hi Liquidcore and Mitch2k2
I have sent you a message. Please check your inbox.
Blanca
Community Team
- LiquidcoreNov 19, 2019StarJust replied to you :)
- FURRYe38Nov 21, 2019Guru - Experienced User
- LiquidcoreNov 21, 2019StarHopefully it isn't a hardware limitation! Your double NAT experiment demonstrating better throughput provides me with some hope that it isn't hardware related.
