Liquidcore
Nov 16, 2019Star
RBR50 unable to handle gigabit connection?
Hi there, I recently purchased the RBK50 to improve the WiFi range in my house and have configured the RBR50 as a router rather than an AP but it seems to be having trouble handling my gigabit connect...
Nov 23, 2019Guru - Experienced User
If your within your return period, I would return it and either get something else or wait until this issue has been solved. It's going to take some time for NG to review, test and fix this issue. Nothing gets fixed in short time frames. Maybe check back with the moderator at some future date to see if it has been resolved or look at FW upate release notes.
I can tell you this, the Orbi AX supports 1Gb fully. Both stand alone testing and live behind my CM1100. So something to review and consider if you wanna give that one a go. :smileywink:
Liquidcore
Nov 23, 2019Star
Unfortunately there isn't really a return policy in New Zealand (especially if the packaging has been opened already), unless you can convince them it's an issue that needs to be covered under warranty.
Sadly the RBK852 isn't available here yet either :(
