rkchang
Mar 13, 2020Tutor
RBR50 Unable to login even after changing admin password
I just recently purchased and installed an Orbi RBR50 set (router + 2 satellites) in our home. I was able to do the initial setup through the iOS Orbi app. Now, I'm hoping to get to some of the more ...
- Mar 13, 2020
Wire connect a PC to the router and factory reset the router using the back push pin button. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Seems like there maybe a problem with the Orbi app and changing PWs there.
Something to post about here in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
rkchang wrote:I just recently purchased and installed an Orbi RBR50 set (router + 2 satellites) in our home. I was able to do the initial setup through the iOS Orbi app. Now, I'm hoping to get to some of the more advanced features that I've seen mentioned to be accessible through orbilogin.net (e.g., changing the default DNS servers, adjusting security level, etc.), as well as see if I can more accurately diagnose why the LAN ports do not appear to be working on one of the satellites.
When I try to load up the webpage via my web browser (tried Safari, Chrome, and Firefox on my MacBook Pro/10.15.3 Catalina), it will not respond to the admin password that I had set up. Even after I go through the process of changing the password via entering the serial number and answering the security questions, it still will not let me log in with the new password, I've set up. I can log in via my iOS app just fine, just not through my laptop's web browser.
rkchang
Mar 13, 2020Tutor
Yes! I can login via iOS app with the new password.
schumaku
Mar 13, 2020Guru - Experienced User
Any Internet "security" software on top if your macOS system? Backgroud: These often block BASIC AUTH on what they consider "insecure", e.g. http only, no valid certificate, ...
- rkchangMar 13, 2020Tutor
To my knowledge, there's no security software on top of this. I do have Sophos Home installed, but this more of an antivirus program rather than a network security solution. Plus, until installing the Orbi, my traffic to certain other websites has never before been blocked.
- schumakuMar 13, 2020Guru - Experienced User
rkchang wrote:... there's no security software on top of this. I do have Sophos Home installed, but this more of an antivirus program rather than a network security solution....
Had fighted with Sophos these days because of captive portals did no longer came up (and still don't...). Currently a fingerpointig issue, Apple and Sophos made some changes...
rkchang wrote:Plus, until installing the Orbi, my traffic to certain other websites has never before been blocked.
There might be not many using http basic auth anymore in the wild Internet.
Sophos does capture almost anything, also on a Mac - Web trafic, web cam, microphone, ...
Uninstall - disabling does not work correct either - and try Orbi again.
