rkchang
Mar 13, 2020Tutor
RBR50 Unable to login even after changing admin password
I just recently purchased and installed an Orbi RBR50 set (router + 2 satellites) in our home. I was able to do the initial setup through the iOS Orbi app. Now, I'm hoping to get to some of the more ...
- Mar 13, 2020
Wire connect a PC to the router and factory reset the router using the back push pin button. Wait for the WHITE led to slowly pulsate on top of the RBR, then log in to orbilogin.com using a web browser and walk thru the setup wizard. This time write down all important information for safe keeping later on.
Seems like there maybe a problem with the Orbi app and changing PWs there.
Something to post about here in the Orbi app forum:
https://community.netgear.com/t5/Orbi-App/bd-p/en-home-orbi-app
Good Luck.
rkchang wrote:I just recently purchased and installed an Orbi RBR50 set (router + 2 satellites) in our home. I was able to do the initial setup through the iOS Orbi app. Now, I'm hoping to get to some of the more advanced features that I've seen mentioned to be accessible through orbilogin.net (e.g., changing the default DNS servers, adjusting security level, etc.), as well as see if I can more accurately diagnose why the LAN ports do not appear to be working on one of the satellites.
When I try to load up the webpage via my web browser (tried Safari, Chrome, and Firefox on my MacBook Pro/10.15.3 Catalina), it will not respond to the admin password that I had set up. Even after I go through the process of changing the password via entering the serial number and answering the security questions, it still will not let me log in with the new password, I've set up. I can log in via my iOS app just fine, just not through my laptop's web browser.
Mar 13, 2020Guru - Experienced User
Good Luck.
rkchang
Mar 14, 2020Tutor
Factory resetting it, then setting up the Orbi through the web interface, instead of the iOS app, seemed to fix EVERYTHING. Not only can I now log in via regular web browser, but this seemed to fix the problem of the Orbi blocking certain websites, and even now the LAN ports on my satellite appear to be working!
Moral of the story: Setting up wireless the old-fashioned way and not through some gimmicky mobile app is always best! :-)
- FURRYe38Mar 14, 2020Guru - Experienced User
Glad the reset worked out and setting up thru web page. Seen odd issues with the Orbi app. I mostly use the web page when setting up any router. Use the app later on for checking on things.
Be sure to do a backup configuration to file for safe keeping now. Saves time if a reset is needed later on.
rkchang wrote:Factory resetting it, then setting up the Orbi through the web interface, instead of the iOS app, seemed to fix EVERYTHING. Not only can I now log in via regular web browser, but this seemed to fix the problem of the Orbi blocking certain websites, and even now the LAN ports on my satellite appear to be working!
