Spazmonkey
May 24, 2022Tutor
RBR50 unresponsive this morning.
Woke up to no wifi and internet today with my satellites glowing magenta. RBR50 is unresponsive and just pulses white. Can't connect to it via Lan using the web interface. Did a factory reset whi...
- May 27, 2022
Fortunately I'd ordered an RBK50 for my boss a couple of years ago which has been sat in our storeroom, as he's not too bothered.
I've grabbed that, and will use the RBR50 from it to recreate my network. Hardly a solution for others that may experience this, but rather than scour ebay for a 2nd hand unit I can get a brand new unit.
May 27, 2022Guru - Experienced User
Sounds like the one unit just died...
Spazmonkey
May 28, 2022Tutor
Looks like it.
New Rbr50 was a v2, but restored my backup to it, updated the firmware and synced my satellites and everything back up and running.
- FURRYe38May 28, 2022Guru - Experienced User
Glad you got something working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
