Anjwld4
Dec 03, 2019Guide
RBR50 update fail
I am a novice at this so patiences is totally recommend. LOL. I was attempting to set up my Echo dots and they kept failing to connect, then I noticed my phone's wifi kept dropping out so I did the...
Anjwld4
Dec 03, 2019Guide
Distance maybe 25 ft, but not over 30, standard wall construction, wood. Nothing in line of sight of the satilite that would interfere
Where do I find the chanels to know which ones I'm using?
Dec 03, 2019Guru - Experienced User
Channels are found under Basic/Wireless Settings on the routers web page.
You might do this first. Turn OFF the RBS. Work with just the RBR and get your devices connected first. Once this is done, then turn ON the RBS. 25feet mabye a bit too close. There is a fine wifi signal over lap that needs to be tuned in. 30 feet is a starting point for most. Mines set out at 40 feet.
Anjwld4 wrote:Distance maybe 25 ft, but not over 30, standard wall construction, wood. Nothing in line of sight of the satilite that would interfere
- Anjwld4Dec 03, 2019Guide
Ok, that makes sense! I'll give that a try, thank you and thank you for your patience.
