JoeM845
Sep 21, 2023Luminary
RBR50: Update firmware from 2.7.4.24 not finding newer firmware
RBR50's Menu item "Advanced -> Administration -> Firmware update" responds with "No new firmware version available" for both the RBR50 and the RBS50. I expected it to find 2.7.5.4, ask for an OK, and...
- Sep 21, 2023
Hello JoeM845 ,
Welcome to the NETGEAR Community!
At this time the most current firmware for the RBK50 systems is an optional update. If you would like to update this firmware please update your firmware manually. Please ensure to update the attached satellites first then update the router last.
Please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#downloadFor step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comBest,
Kevin
Community Team
CrimpOn
Sep 21, 2023Guru - Experienced User
JoeM845 wrote:
Is my expectation correct?
This will happen when Netgear "flips a switch" somewhere that informs the router that this new firmware is available to install.
Until that happens, customers who want to update to this firmware can perform a manual update.
- JoeM845Sep 23, 2023Luminary
Thanks, but since this fw version was released in February, I expect that it is as "generally available" as it is going to get.
- CrimpOnSep 23, 2023Guru - Experienced User
So true. This one of the most frustrating aspects of Netgear product support. One would think that firmware released in February that includes "bug fixes" and "addresses security vulnerabilities" would be "ready for prime time" by September.
It could be as simple as the person who was tasked to move the firmware status to "searchable" has left the company or been reassigned to another role. The Orbi AC product line is long in the tooth and one might imagine that significant resources are dedicated to resolving major issues with the AX product line (which inhibit further sales) or to the new WiFi7 products in the pipeline.
Having only Netgear WiFi equipment, I have no idea how often other vendors update firmware or how their update process works in practice.
