JoeM845
Sep 21, 2023Luminary
RBR50: Update firmware from 2.7.4.24 not finding newer firmware
RBR50's Menu item "Advanced -> Administration -> Firmware update" responds with "No new firmware version available" for both the RBR50 and the RBS50. I expected it to find 2.7.5.4, ask for an OK, and...
- Sep 21, 2023
Hello JoeM845 ,
Welcome to the NETGEAR Community!
At this time the most current firmware for the RBK50 systems is an optional update. If you would like to update this firmware please update your firmware manually. Please ensure to update the attached satellites first then update the router last.
Please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#downloadFor step-by-step instructions on how to manually update your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-comBest,
Kevin
Community Team
KevinLiT
Sep 21, 2023NETGEAR Moderator
Hello JoeM845 ,
Best,
Kevin
Community Team
RocketSquirrel
The very sparse release notes state
- Various Armor bug fixes
- Various SPC bug fixes
I have no idea what Armor and SPC are. What are they?
- FURRYe38Sep 21, 2023Guru - Experienced User
Armor is router based security app.
SPC is Smart Parental Controls.
