EricToo
Feb 09, 2021Aspirant
RBR50 Update to Firmware Version 2.7.2.104
I attempted to upgrade to Firmware Version 2.7.2.104 The update attempt failed and I could no longer access the router by logging in on my computer. This occured shortly after the firmware was r...
vajim
Feb 09, 2021Master
from your post I can't make out if you have a problem or not.
with regard to 2.7.2.104, I would do a search in the forum. Lots of folks having problems as well as using the app. Many have dumped the app. I never use it.
