EricToo
Feb 09, 2021Aspirant
RBR50 Update to Firmware Version 2.7.2.104
I attempted to upgrade to Firmware Version 2.7.2.104 The update attempt failed and I could no longer access the router by logging in on my computer. This occured shortly after the firmware was r...
Feb 09, 2021Guru - Experienced User
Power OFF the RBR for 30 seconds then back ON.
Be sure to clear out all browser caches.
Use IE11, Edge or Firefox to access the RBRs web page at 192.168.1.1 or orbilogin.com
Last resort is to do a factory reset on the RBR and walk thru the setup wizard with a web browser.
Avoid using the Orbi app for any FW updates.
The update attempt failed and I could no longer access the router by logging in on my computer. This occured shortly after the firmware was released, October of 2020 as I remember.. The Netgear tech support team could not fix the issue.
Yesterday I logged into the router from my cellphone app. A button appeared. Clicking on it upgraded the firmware to v2.7.2.104. on the router and two satellites.
WOW!
So today I tried to logon from my computer again to see what would happen. Same problem as before. I can completed the logon sequence, but could not access the web pages showing router and satellite status (or anything else for that matter). So I went back to the cellphone and all seemed to be ok.
Currently, the orbi system is functioning normally (just as it was before the upgrade).
Does this behaviot suggest a known orbi RBR50 problem? Has anyone seen this sort of thing before. Does it suggest some sort of hardware problem? So sort of persistent firmware problem? Something else? Ca this issue be fixed? Any suggestions at all about what else, if anythiing, can be done?
EricToo
Remember. The Netgear tech support team with escalation could NOT fix the issue. I coonsider this to be a significant matter because Netgear advises that no firmware updates be performed using the Netgear app.
- vajimFeb 09, 2021Master
EricToo wrote:Remember. The Netgear tech support team with escalation could NOT fix the issue. I coonsider this to be a significant matter because Netgear advises that no firmware updates be performed using the Netgear app.
If only more people here understood that this would be a happier place to exchange ideas and experiences.
- alokeprasadFeb 09, 2021Mentor
EricToo wrote:... Netgear advises that no firmware updates be performed using the Netgear app.
Where/how does Netgear say that?
I happen to agree with it .. but I'm surprised that Netgear would advide that. They seem to be pushing their smartphone apps in the marketing materials.
As long as the app is available they probably will never officially say that. It comes with the territory. There's nothing wrong with the concept of an app for they are very popular in todays streaming environment.
IMHO NG may not have devoted enough resources to the app development based on return of investment or a misunderstanding of what the app was intended for. For me personally I never use the app.
More the reason for my curiosity about how/when NG said that (per EricToo).
