Philip_Timms
Jun 18, 2020Aspirant
RBR50 upgrade
I have an RBK50 set up - one RBR50 router and one RBS50 satellite. I am feeling the need for just a bit more power and coverage to be able to use an outdoor satellite properly (and, yes, I have the latest firmware!) - what would the next step up be in the Orbi universe?
What is the distance between the outdoor RBS and the RBR?
- Philip_TimmsAspirant
Hi
The distance from the router to the satellite is about 10m vertically, 8 m horizontally through a substantial brick and timber Victorian building.
Philip_Timms wrote:I have an RBK50 set up - one RBR50 router and one RBS50 satellite. I am feeling the need for just a bit more power and coverage to be able to use an outdoor satellite properly (and, yes, I have the latest firmware!) - what would the next step up be in the Orbi universe?
"Step Up" is a complicated question, because that basically involves what we used to call a "fork lift upgrade". i.e. change out everything. The obvious advice is to go with a WiFi 6 system, but which one??? (from which vendor and which model) Are you so enamored with Netgear Orbi that you will only consider a "better" Orbi?
