FedM
Oct 09, 2019Aspirant
RBR50 upload speed it twice lower than download
I have a single RBR50 in my apartment that works in router mode My ISP gives me 500/500. All devices use wifi connection on 5Hhz When I do a wireless speedtest with macbook pro or iphone X in...
Oct 09, 2019Guru - Experienced User
This would be one reason: "But if I move to the next room or kitchen, which are behind 1 concrete wall, the UL speed appears to be almost twice lower than DL speed"
Regardless of wifi signal, building materials like Concrete will impact wifi and performanced. Not idea of any kind of wifi.
- FedMOct 09, 2019Aspirant
Well, it could be so, but two previous routers (Google and Ubiquite Amplifi HD) are not affected my the walls and perform the same DL and UL speeds. Both speeds dicreases the same way 500\500-----a WALL-----300/300
- FURRYe38Oct 09, 2019Guru - Experienced User
Concrete matierial can effect wireless signal differently.
Can see if any of these suggestions help:
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. With Concrete, you may need to move RBS closer to the RBR.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).- FedMOct 09, 2019Aspirant
ok
I havу just tested the speed in the same room where the router located, so no walls, but about 10 feet from the router
The results are 480\400. Repeated three times, almost the same always
Noticed your full reply too late sorry
