FedM
Oct 09, 2019Aspirant
RBR50 upload speed it twice lower than download
I have a single RBR50 in my apartment that works in router mode My ISP gives me 500/500. All devices use wifi connection on 5Hhz When I do a wireless speedtest with macbook pro or iphone X in...
FedM
Well, it could be so, but two previous routers (Google and Ubiquite Amplifi HD) are not affected my the walls and perform the same DL and UL speeds. Both speeds dicreases the same way 500\500-----a WALL-----300/300
Oct 09, 2019Guru - Experienced User
Concrete matierial can effect wireless signal differently.
Can see if any of these suggestions help:
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. With Concrete, you may need to move RBS closer to the RBR.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
- FedMOct 09, 2019Aspirant
ok
I havу just tested the speed in the same room where the router located, so no walls, but about 10 feet from the router
The results are 480\400. Repeated three times, almost the same always
Noticed your full reply too late sorry
I have no setellites, just a single RBR
2.4hhz channel is set to Auto (Ive seen just my iphone only once switched to 2.4, all other devices work on 5hhz all the time)
5hhz channel is set to 48, the unused one. Ive tried every posibble chanel and the issue is still exist
Beamforming, MIMO and WMM enabled
Where can I find the last settings you mentioned?
- FURRYe38Oct 09, 2019Guru - Experienced User
Well there is another consideration as well. Having a single wifi source with concrete around, the single source can only do so much. You might want to consider adding a RBS to help with this building configuration.
Addind a satellite will make the signal stronger but will not increase speed I think
I cant see Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only in Advanced\Advanced setup\wireless settings
Here is what I have
plus MIMO and Beamforming lower
http://imglink.ru/pictures/09-10-19/dce2dc33e0b5f57432167787d941b30b.jpg
