Ruze69
Sep 12, 2018Aspirant
RBR50 (US Router w/3 Indoor Satellites Online) & RBS50Y Outdoor Satellite) will not Sync
Have a RBR50 + 3 Satellies Online and up for over 6 months.
Adding a RBS50Y Outdoor Satellite.
Syncing to Router unsuccessful. Even when located within the same room during Sync Process. ...
- Sep 15, 2018
Thank You for the reply.
I keep my RBR50 Firmware "Auto" updated in these times. But, I was unable to access the RBS50Y unit without a Ethernet connection.
I did find another obscure note while searching. Coincidence or not....
It recommended Multiple Power Button Cycling after a 60+ second reset.
It worked.... That is coincidence or Top Secret stuff! Lol!
The unit was used to replace a standard Satellite and is awesome! Highly recommended!
Thanks for the assistance Good Luck to all!
Sep 13, 2018Guru - Experienced User
I would make sure the FW is up to date on the RBSY unit, then the unit should connect.
