Daru
Oct 01, 2017Aspirant
RBR50 used with cable modem creates unneeded network. How to delete?
My system is RBR50, not RBK. I've entered RBR50 several times, deleted this RBK several times, and can't get rid of it. macOS Sierra 10.12.6, latest firmware I use an Arris Group cable modem ...
- Oct 01, 2017
The sole purpose of Orbi in AP mode is to create a WiFI network. If you are using Orbi with a cable modem, you should turn off the cable modem's WiFi and use Orbi's.
aaz
Oct 01, 2017Virtuoso
Daru wrote:My system is RBR50, not RBK. I've entered RBR50 several times, deleted this RBK several times, and can't get rid of it.
I use an Arris Group cable modem to connect to the internet, and Orbi18 router and three satellites to create my LAN. I changed the Orbi Router to serve as an Access Point, yet it still creates the Orbi18 network. The first time I used it, it did not create the Orbi18 WiFi, but after first use, ever since then, it has created it. I have deleted it from the list of known networks on my computers, but can't do that on iOS devices.
If there is a moment of disconnect, devices change from my Arris WiFi to the unusable Orbi18 WiFi, which has no internet connection. How do I get rid of the Orbi network?
You'll need to explain this again, as I cannot follow what you are trying to do?
It seems like you have an Orbi - which is meant for WIFI access and you don't want to use it for WIFI - and you don't want to use it as your router (which is the ARRIS) - so why do you have an orbi on your network?
- DaruOct 02, 2017Aspirant
"Orbi - which is meant for WIFI access and you don't want to use it for WIFI - and you don't want to use it as your router (which is the ARRIS)"
Arris modem is not my router. Arris makes the connection to Internet. Orbi router and satellites create my LAN. Orbi is creating LAN quite well, covers three buildings, but it also creates an Orbi18 LAN which is not connected to the internet. At least, that's the way I understand it.
My IP scanner does list the Arris as my router and the Orbi as my modem. Backwards. But my LAN seems to be functiong any way. Northland Cable apparently errrored advising me on setup. I'll get into the Arris and hopefully get it corrected.
Thank you for your help.
