Daru
Oct 01, 2017Aspirant
RBR50 used with cable modem creates unneeded network. How to delete?
My system is RBR50, not RBK. I've entered RBR50 several times, deleted this RBK several times, and can't get rid of it. macOS Sierra 10.12.6, latest firmware I use an Arris Group cable modem ...
- Oct 01, 2017
The sole purpose of Orbi in AP mode is to create a WiFI network. If you are using Orbi with a cable modem, you should turn off the cable modem's WiFi and use Orbi's.
st_shaw
Oct 01, 2017Master
Daru
Oct 02, 2017Aspirant
Yes, that’s what I want it to do. But it seems to be creating two: the one connected to the Arris modem and another Orbie 18 LAN with no internet. The one connected is fine. Serves 3 buildings. I’ll check later, but as I recall, different IP address.
