Daru
Oct 01, 2017Aspirant
RBR50 used with cable modem creates unneeded network. How to delete?
My system is RBR50, not RBK. I've entered RBR50 several times, deleted this RBK several times, and can't get rid of it. macOS Sierra 10.12.6, latest firmware I use an Arris Group cable modem ...
- Oct 01, 2017
The sole purpose of Orbi in AP mode is to create a WiFI network. If you are using Orbi with a cable modem, you should turn off the cable modem's WiFi and use Orbi's.
st_shaw
Oct 01, 2017Master
Daru
Oct 02, 2017Aspirant
You are absolutely right. Just checked my IP Scanner, and it does list the Arris as the router, not the modem. It actually says the Orbi is my modem, which desn't make sense. The cable is atached to the Arris. The mesh sytem seems to be working anyway. I'll see if I can get into the modem; f not, I'll call Northland Cable, but they gave me erroneous information when setting up.
Thank you very much
