cblaze22
Mar 06, 2021Tutor
RBR50 V2.7.2.104 Firmware update now is dropping signal randomly
I had a working mesh system with my RBR50 and 1 satellite for almost two years. I just updated to V2.7.2.104 and now drop signals all over the place. I even reverted back to older firmwares and st...
cblaze22
Mar 06, 2021Tutor
I may of figured out the issue. I decided with my original setup to split the 2.4 and 5 into their own channels via telnet. I kept doing this after the firmware update.
This time I decided to keep it on one band and I havent had any drops yet. If I see any drops Ill let this thread know but until then it looks like the newer firmware are having issues with split channel names.
I reverted back to an older firmware, however I didnt know the exact firmware. I went to 2.5 and was the same issue so I probably had a firmware originally that did not cause issues with the dual channel names.
vajim
Mar 06, 2021Master
Wow
lots of changes and tweaks
good luck
