dmn11
Mar 15, 2021Tutor
RBR50 V2.7.2.104 Port forwarding not working
Hi
I use to be sys admin few years ago so I have good network understanding.
I have setup multiple port forwarding to multiple devices on my network
For some reason none of them work
All the internal devices are using fixed IP (set by the Orbi router)
I know my external IP address, when I do a Nmap scan to see if I have any open ports my network it finds 0 open ports
I cannot find any reason why the port forwarding doesn't work
Will appriciate any ideas
Thanks
- dmn11Tutor
Solved the problem - it was my modem
It reset and switched from a bridge to a router so my Orbi was behind another network
