Len6
Aug 26, 2022Aspirant
RBR50 V2.7.4.24 that I am unable to clear Security Options (WPA2-PSK) password.
I have reset the router using the pin hole and electronic reset using the interface. I have the password that I used to log into the admin side of my Orbi that keeps returning to the Security Option...
- Aug 29, 2022
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
Len6
Aug 28, 2022Aspirant
I made all the recommended changes for option 2 and used the 192.168.0.1 and everything is working great now, and the password stopped changing. Thank you for your help. Any additional suggestions.
1.Implicit Beamforming, MU-MIMO, and WMM activated.
2.Daisy Chain - Active since I have floors all satellites up from each other and not spoked.
3.Fast Roaming off.
4. Armor on
5. IPv6 on DHCP and supported by ISP
6.Enabled 20/40 Mhz Coexisting
7.Using channel 6 for 2.4 and channel 36 for 5
8. Guest Network -off
9.Remote Management on
10.Static IP Addresses for every device and satellites.
Aug 29, 2022Guru - Experienced User
Enjoy. 📡
