Atlixnor
Oct 16, 2023Guide
RBR50 v2 firmware update -automatic upgrade not working. Need advice, please
Why is the GUI automatic fw update not finding a new firmware? The current fw is 2.7.4.24, and I am based in Europe. Is this the reason the automatic fw is not working? I want to upgrade ...
Atlixnor
Oct 16, 2023Guide
ok. I upgraded satellites, router, and shut down everything and turned it on in the right direction (modem, router, satellites).
Wifi is again working fine for everything except my expensive Pixel 8 Pro. I cannot believe it is not working. It is flapping on and off. I will provide a video and wifi settings here soon. Google is going to start monitoring my phone to troubleshoot this also unless you guys finds a solution fast.
Atlixnor
Oct 16, 2023Guide
- AtlixnorOct 16, 2023Guide
- CrimpOnOct 16, 2023Guru - Experienced User
Thanks for the delightful video. The Pixel 8 Pro supports all sorts of WiFi standards that are not provided by the 802.11ac Orbi product (802.11ax [WiFi6} - WiFi6E - WiFi7). One would certainly think that "backward compatibility" would be "no problem."
Would it be convenient to:
- Temporarily power off the TP-Link WiFi system.
- Temporarily disable LTE data on the phone.
- Uncheck the 20/40 compatibility option on the Orbi.
- "Forget" those three WiFi network SSIDs.
- Attempt to connect again?
hi,
Thanks for your advice. I wil test this later today. That is about the only option I have not tried, bu tI thought about it (20/40 coexistence). Hopefully it is this, because it works fine other places. The TP-Link is not connected anymore as well at the moment, just running on 4G.
