Atlixnor
Oct 16, 2023Guide
RBR50 v2 firmware update -automatic upgrade not working. Need advice, please
Why is the GUI automatic fw update not finding a new firmware? The current fw is 2.7.4.24, and I am based in Europe. Is this the reason the automatic fw is not working? I want to upgrade ...
CrimpOn
Dec 18, 2023Guru - Experienced User
v2.7.5.4 is the latest firmware (released in Feb, 2023). If you look closely at the Orbi web management, there is probably a period between the 5 and 4 on your router firmware version.
Yes, any manual firmware update works the same way
- Download and upzip
- Connect to each satellite web interface and upload firmware
- Connect to router web interface and upload firmware
There is one "gotcha" lurking. Whereas Netgear finally added a feature to the AX series products to allow the user to enable/disable Automatic Firmware (without asking if the user wants to do so), that feature is not present on the RBR50 product. If Netgear finally decides, "It's time", they can push v2.7.5.4 onto your system. (or any newer version than the one you loaded)
I am aware of a major crisis involving the newest version of iOS (17) and lots of WiFi systems (not just Netgear). Am not aware of any issue with Android/Wiindows problems. My RBR50 has been on v2.7.5.4 since last February and all my Android/Windows/Apple/Nest devices work just fine.
Atlixnor
Dec 18, 2023Guide
My disconnection stopped on the Samsung S21 when I reverted back to 2.7.4.24
Now I will have to stop the store from sending my Pixel 8 Pro to google for investigation. There is a chance now that their December update actually fixed my problem, so have to extinguish that possibility before they wipe my device and maybe say nothing is wrong with it.
- AtlixnorDec 20, 2023Guide
So I reset to factory settings. So far all devices are stable (Also Google Pixel 8 Pro). Wifi channel is Auto. I notice the advanced wifi settings for default are quite different from what was recommended here some years back. What should I tweak there as a minimum? I do not want to cause any instability again.
- CrimpOnDec 20, 2023Guru - Experienced User
If it ain't broke, don't fix it.
- AtlixnorDec 20, 2023GuideIt actually still drops...So need to do some tweaking. If it keeps dropping I will bring everything to my cabin and setup once more, and if it still drops there, I have a case with the retail store.
