Irving753
Aug 28, 2022Follower
RBR50 v2 Router Magenta Ring
Orbi had worked fine for 1.5 years, last week started having intermittant issues, got the magenta yesterday. I've tried power cycling, factory reseting and swapping ethernet cables.
Spectrum modem shows no issues on their end. After one of the factory resets it did show internet access for a bit but the security certification were always wrong and then the internet fully disconnected shortly after.
Sometimes the internet port shows its connected sometimes it doesn't as you can see in the attached.
Not sure where to go from here.
1 Reply
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
Looks like your ISP modem may have a built in router.
This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
FYI, please edit out any MAC addresses and product serial numbers in pictures before posting in public forums for security reasons.
